Results 1 to 7 of 7
    di Member doug's Avatar
    Feb 2011
    clare
    Default dash and rear lights not working s14 (jap)
    as title says i was driving there a while ago an the dash lights an rear lights just stopped working, the front parks also
    every thing else works fine.
    i havent checked fo any loose wires other than the ones going into the rear lights as its gettin dark and i was at the side of the road, it keeps blowing the 10amp fuses too.
    any one know where i can get a wiring diagram for the lights or any info what can cause it?
    eg whats connected to what,
    any info? thanks!
    di Member gary g's Avatar
    Dec 2009
    galway
    are you running anything else of the power wires going to the lights like strobes,neons etc
    Motionsick Media Keli's Avatar
    Gorey, Wexford
    Put in a 20amp fuse, twill be grand
    di Member sheepo's Avatar
    Dec 2010
    same thing happend my s15...i was after putting after marked light in the back and it kept blowing the 10amp fuse on me every time i put it in...its just getting a short circuit somewhere...i jus put in a 30amp fuse and job done
    Prominent Member mickel's Avatar
    Leitrim
    Quote Originally Posted by doug View Post
    any info? thanks!
    check the loom over the drivers wheel
    could have dropped down and the wheel
    might be rubbin off it
    [SIGPIC][/SIGPIC]
    Feb 2011
    clare
    Quote Originally Posted by mickel View Post
    ill do that today. It happend after doin a little sliding. Cheers!
    Im not running any after market things off them but i do think there was raybrig strobes in it before the controler is still in the car.
    Maybe a loose wire somewhere
    Feb 2011
    clare
    99.99% sure ive it fixed.
    was a wire tapped onto the back lights and when i chased it back it wasnt ocnnected to anything so i removed it an now its all working perfect.
