Results 41 to 50 of 88
    Default CS-Autos S15 Mark Synnott
    here is a quick rundown of the new panic project! the car has been sitting here for a while now but we only stared into it yesterday, and it has to be out for prodrift round 2 in fermoy on 3 weeks time!!!
    so quick spec on the car when we got it:
    01 specR s15 shell
    s14 engine and 5 speed box
    full interior
    full body kit
    +30mm vented wings
    +30mm over fenders
    full stock suspension
    some crappy tail lamps
    and bits waiting to go on:
    temparay 6point bolt in cage,
    red top sr20det tdp pullys, mhg, nismo 550cc's, je pistons, acl bearings
    z32 afm
    Apexi power fc
    full 3" exhaust system
    full trust td06 20g turbo kit
    big trust fmic
    alloy rad
    orc twin plate clutch
    rb25 box
    omori oil temp, oil pressure, water temp gauges and apexi rsm, built into dash cluster
    gtr pump
    custom loom
    pair of seats and harnesses
    sparco dished wheel
    hydro
    skyline brakes all round
    project MU braided brake lines all round
    hsd cs2 coilovers
    cusco rear camber arms
    cusco rear toe arms
    driftworks rear traction arms
    custom CS-Autos front steering lock
    driftworks front lower wishbones
    cusco tension rods
    when we first got the car we pulled the engine and box and sold them, then the interior came out most of this is still here if anyone need bits???? sound deadining out came out last month then it sat there, then yesterday it came in for some real work, fired in a bolt in cage for a test fit and to cut the dash so we can paint the inside of the car and the cage and not worry about marking them when fitting the dash at at later date,
    PICS:
    firstup were the rear arches dan moorhead had done a very nice job flairing them out the the overfenders before but it was just going to be a roadcar then so i did a bit of a job on them, will allow lots of lowness and decent wheel to over fender gap,
    i forgot to take a pic of the drivers side before i did it but here is the passo,
    tunnel cut out to make more room for removeing and fitting the rb25box
    then the boot floor came out!!
    it will be left as above, and will be fire/smoke walled at the rear parcel shelf/ rear seat back,
    then moved on to the front, the battery died in the camera after this pic move to come soon
