Results 1 to 10 of 26
    Put about 3 washers in each side......! 4 if your feeling brave....! And cut your lock stops....! U will notice the difference.....!
    if you dont have spacers on front don't put in four as it will start rubbing, 3is bang on but if you have spacers go for it jus once your getting couple of threads back into the rack if you know i mean...euro coin is exactly 2mm so if you use 3coins = 6mm. so you need to adjust your rack ends that amount to even her out...pm if you'v any hassel mate
    niall here
    serious difference lad I use spin a good bit but in doin this it has reduced it alot
    di Member S13..KEV's Avatar
    ya the washers are a good job and cheap way to do it but then ya run into more problems like over center.which can be a pain in the hole
    PS if you do go with it.keep an eye on the the thread left on the tie rod going back into the rack.can be left with very little thread and will be dangerous.could end crashing it over cutting cost
    Dublin
    Quote Originally Posted by S13..KEV View Post
    Might go with 2/3 washers and locktite the rod going into the rack then
    Quote Originally Posted by si_berry View Post
    job done dude.first few runs in it.just keep an eye on it to be safe.my advice would be save up on but the just jap extra lock kit or seamie's kit.end all youre worrys
    jaysus kev hope that doesnt happen me
    yea lad thread lock aswel thats exactly what i done....dont worry bout 235s have them on front also ya need ur grip at end of day...
    kev u have me freaked now haha....into the wall down the straight of mondello
    Dublin
    Did you have problems before kev with this? Or are you just being cautious.
    Quote Originally Posted by B&G Extreme Drifting
    Sound, i'll see what it looks like with the 3 washers anyway, locktite the shit out of it!
    Dublin
    Quote Originally Posted by B&G Extreme Drifting View Post
    niall here
    Cheers lads, I have 235's on the front, will this affect it, should I be dropping the width aswell, maybe 205/215's?
