Results 1 to 3 of 3
    Default 1JZ sump baffling needed
    rite i got the new soarer up and running and need the sump baffled as above i was told you have to have certin measurments and angles for it to not mess up the engine can anyone shed some light on the subject and know anyone who can do a proper job thanks
    has your oil pickup have a cover over the mesh.if it has cut the cover off ,this is the only oil modification needed on the jz sump
    well i was told to baffel the sump and stick an oil cooler in coz i dont want the same to happen to this engine as the last
