Results 1 to 10 of 12
Thread: Fucking camber!
    di Member jdmjimmy's Avatar
    Default Fucking camber!
    Ok fitted the camber arms from my s14 to the s15
    note
    No bent arms !
    No bent shocks !
    sub frame all inline
    Now for the annoying bit!
    The left wheel looks like its .5" cambered in more than the driver side and its wrecking my chops!
    My thinking when the car got a tip on the left rear the inner quarter panel may have been pushed back out too much leaving the over fender out of shape and giving the illusion of negative camber..
    any help appreciated or anybody who has any history of when the car was quick fixed after this crash
    YouTube - drift crash
    galway
    dude my s13 had the same problem, one side looked more cambered than the other, i put it down to the overfenders making it look that way best thing to do is get it set up properly, then you will know for sure!
    its setup the same both sides I think your right gonna rip off the over fenders and re fit them after mondello if i get out!
    Ive often put hours into setting up cars & when finished looked at them & put them back up again because i doubted the results.
    It can become head wrecking. If the setup is reading correct Id not worry too much about looks because we all know most cars have had some battle scars in the past.
    WWW.WKDIMPORTS.COM
    hadnt a snot of credit to txt you earlyer lad, id say it something to do with the slap alright, if its set up right and looks off it has to be
    from wat i remember back in the day that shell had more slaps then most
    if the arms r right id go by them
    Cheers for the input lads...Fuck it sure il take off the quarters and try sort it that way..
    @ podge
    I dont think it got any major hits just the wall as in the vid and a wheel came off in rosegreen ..
    @ gem
    sound sure if your in mondello il get ya to throw an eye at her see what ya athink
    Quote Originally Posted by jdmjimmy View Post
    @ podge
    @ gem
    It got a serious rear end shunt in Nutts corner once. We pulled it out with the Volvo loader. lol.
    WWW.WKDIMPORTS.COM
    Quote Originally Posted by wezwkd View Post
    yea thats the vid above ah sure that would be a good reason why sounds a bit of a thick effort but sure there was plenty of money back then top do such an act!..Il sort it out after mondello porta power and a bit of advice from Gem should do the trick..
    Dec 2009
    Straightened this car with ratchet straps on a number of occasions lad.
    Should be fine tho, good to see it looking decent again, I have alot of pics ill get up soon.
    [SIGPIC][/SIGPIC]
