mynes a 1994 non vvt blacktop
all 180sx engines are non vvt,,
there is the red top engine and the black top engine in the 180sx,the blacktop is not to be confused with the blacktop that is in the s14/s15's...the black top engine in the 180sx is non vvt.
085 8894526
[QUOTE=jamie180sx;245026]all 180sx engines are non vvt,,
there is the red top engine and the black top engine in the 180sx,the blacktop is not to be confused with the blacktop that is in the s14/s15's...the black top engine in the 180sx is non vvt.[/QUOT
yes jamie you are right but try tell mr know it all robbie that.. he seems to come on here and take over all these kind of thredas with all his knlowage(spelt wrong) come on robbie your up..
Its a 94 180sx lads , , Blacktop engine and it is defo between 2 and 3k revs!!
poor robbie is getting serious stick on this 1![]()
none of the "straight cam" or (red top/black top) 180sx /s13 silvia's have vvt engines are easily identified by having a hump or slant on the rear of the rocker cover which is known as bent cam or vvt model from s14's and s15's 65f is also the block number stamped on the front of the vvt engines also has upturned inlet manifold unlike straight cam which is upside down..As for the rattle id be thinkin bottom end and nothing that rattles is a simple fix! like any fool would know the same..
