Results 1 to 10 of 11
    di Member Dori88's Avatar
    Donegal
    Default More Boost from the 180 ????
    Well Guys
    My 180 is a standard non vvti sr20det
    Only Power mods it has is a kakimoto RS-R exhaust, downpipe, FMIC and GTR fuel pump.
    Its got a standard turbo and is boosting at only .5 bar
    I recently took the car to a few drift days and got on grand but obviously enough the car is very underpowered for 2nd
    I was asking around and was reccommended a digitial boost controller and actuator. Was just wondering if anyone has any tips on what to buy to get her up the power before the next drift day at the end of november OR what type of actuator or boost controller to get?
    Any info at all is much appreciated
    Cheers
    Matt
    Dec 2010
    all depends on your budget lad?
    Donegal
    Quote Originally Posted by darren C View Post
    well i dont want MENTAL power, just up to around the 300 and id be happy with that
    dont want to go into internals or anything like that
    Sep 2010
    kerry
    s15 turbo seems to be a very good upgrade...i had a hks actuatopr.s15 bb turbo.fuel pump and exhaust on my old 14 and was very able for 2nd.
    Donegal
    Quote Originally Posted by dermot-r32 View Post
    i got a 15bb turbo with the car (not fitted) and it seems dead on but there is a tiny amount of play in the centre cartridge, some say it needed replaced, others said it was bang on but iv yet to try it out
    The 15 turbo should make it more responsive aswell as its very laggy at the minute down low revs
    what all else do you need to fit the 15 turbo???
    would 15spec R 440 injectors make much of a differnce as there is a GTR pump in it?
    Site Trader: TDP - Trackday Performance
    The best thing to increase the power on an engine is to map the ECU.
    We can supply a NISTUNE ecu that wil find all the power in the modifications you have. It can also control the boat with a simple TDP boost solonoid. It's by far the most cost effective way of increasing power and torque.
    In the future if you do further upgrades it can be mapped to suit.
    We could get your current spec to about 300 bhp with great torque and response without changing the turbo or injectors.
    Robbie
    Quote Originally Posted by robbie@tdp.ie View Post
    Robbie
    Would a T25 make about 300bhp?
    Just about but it falls off very quickly. This one made 289 I have seen more.
    Here is a 180 with T25 that I was asked to max recently. Its turbo was failing as I started so a fresh one might do better.
    Here is the Torque and Axel BHP.
    Here is the Flywheel Torque & BHP
    The boost falls of very quickly.
    Robbie
    When you say laggy what sort of rpm are you reaching .5bar?you could have a boost leak or your actuator is gone weak or maybe have a slight leak in your turbo gaskets.
    Also there is a t piece on your vacum hoses just above the turbo one goes to back towards the trottle body another goes to the standard boost factory boost solenoid and the other goes to the turbo actuator remove the one going to the factory boost solenoid and replace with silicone hose or another vacum hose as this pipe contains a restrictor and hey presto you have .7bar and with your set up you should be able to run that safely.
    Robbie
    Impressive....There life span couldnt be all that long running at them kinda figures tho could it?
