Disconnect the blue silicone hose from the hot pipe/pipe leading to the intercooler and run that to the solenoid port marked com then run the black hose from the port marked no to the hot pipe.Only thing Is what is your avcr set to?you will have to turn that off or lower the boost on it.hope this helps
