Results 1 to 10 of 11
    Senior Member ste's Avatar
    north dublin
    Ye it shows boost on the avcr, just really want everything connected and workin
    easy enough to sort mate but kinda hard to explain over the web if ya know what i mean can pop up and sort it for ya if ya want some evening!
    north dublin
    Quote Originally Posted by will_c View Post
    Will c thanks man but cars not road legal
    Disconnect the blue silicone hose from the hot pipe/pipe leading to the intercooler and run that to the solenoid port marked com then run the black hose from the port marked no to the hot pipe.Only thing Is what is your avcr set to?you will have to turn that off or lower the boost on it.hope this helps
    Oct 2010
    Don't know much about the boost controller but tighten the shit outta those nuts on the elbow.I replaced the turbo gasket before and only gave them a pinch.a week later they had all fallen out!!
    I had that problem with the bolts before make sure there is washers on them.
    What i done was used lock nuts never had the problem with opening again
