sending it on another tab, a lad wants to swap a 14 for it, yes please....
Yeh they go a certain way tho com-actuator, No-boost.........
Originally Posted by sc86
better thread would be pics of all the savage jap cars parked up hidden around the country in sheds!
No because whores like you will buy em and break em
Is the avcr pressure sensor/map sensor connected??is it showing boost on the avcr?if not there isnt not much point connecting the solenoid.
Ye it shows boost on the avcr, just really want everything connected and workin
easy enough to sort mate but kinda hard to explain over the web if ya know what i meancan pop up and sort it for ya if ya want some evening!
Disconnect the blue silicone hose from the hot pipe/pipe leading to the intercooler and run that to the solenoid port marked com then run the black hose from the port marked no to the hot pipe.Only thing Is what is your avcr set to?you will have to turn that off or lower the boost on it.hope this helps
Don't know much about the boost controller but tighten the shit outta those nuts on the elbow.I replaced the turbo gasket before and only gave them a pinch.a week later they had all fallen out!!
I had that problem with the bolts before make sure there is washers on them.
What i done was used lock nuts never had the problem with opening again
