    Default Body Sculpture BR-3060X-H Magnetic Rowing Machine
    item is never used - good as new
    collection from Carrick on Shannon Co. Leitrim
    Brief Description: This quality rowing machine features light but strong construction providing durability, looks and super smooth operation. The easy to use computer monitors a variety of statistics and shows them on it's LCD display, including your heart rate, which is measured by the hand grip system while grasping the handlebars.The adjustable footplates are great for people of any stature. They pivot as and when needed and feature easily adjustable velcro straps. The aluminium glide rail and polyurethane slider wheels make for a super smooth movement, and with the central pulley position make for a great rowing experience. The magnetic breaking system is surprisingly quiet if you're used to using air or water systems.
    Storage is simple, this rower folds up around two hinges, and when you're ready folds back out in a moment. No disassembly/assembly required before exercise.
    With this quality and these features the BR-3060X-H is a great bargain.
    Computer: This computer is simple to operate and has a clear LCD. It monitors and displays:
    * Hand Pulse
    * Scan
    * Time
    * Count
    * Total Count
    * Calories Used
    Magnetic Braking System: Magnetic breaking for greater control with quieter performance.
    Slide Mechanism: The aluminium slide rail combines with polyurethane rollers for ultra smooth movement and great durability. The slide has a long easy movement for users of all heights and allows full leg involvement in the rowing stroke.
    Seat: The seat is made of polyurethane, and is large and comfortable.
    Storage: Hinged in two places, the unit folds away easily into a compact package (see images below for more detail).
    Construction: Aluminium rail and polyurethane slider wheels for smooth movement and durability, aluminium body, plastic cosmetics and control panel, foam coated handles and polyurethane seat.
    Max User Weight: 100kgs
    Gross Weight: 21.6kgs
    Build Up Size: 186 x 51 x 46.5 cm
    Fold Up Size: 83 x 51 x 100 cm
    150 euro
    I'm all for gay marriages.......it makes domestics in the home that lil bit fairer
    open to offers
