Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Q on coilpacks
    Aug 2010
    Default Q on coilpacks
    ^^^^^^how can I tell if there wrecked or not?
    €300 + for a set, way too rich for me to be buying new ones
    http://tyresdublin.ie/
    https://www.facebook.com/pages/Tyre-...42971845756587
    Quote Originally Posted by daz1996 View Post
    fair enough and all that but you make it sound like your fuckin james bond risking your life everytime you take a few pics
    Cork, Ireland
    Why not just get a wasted spark kit, €100?
    TEAM MANFOOT
    Aug 2010
    Quote Originally Posted by Chuck_g View Post
    Whats a wasted spark kit? Does it eliminate the coil-packs? Don't know much about them
    Aug 2010
    OK read up a bit about the wasted spark kit, they eliminate original coil packs if im correct?! as they are prone to overheating and dying. Does anybody know where I can get these for a CA on short notice like today or tomorrow?!!!!!
    MEATH
    Try a set of coil packs for a ca in the skip last week, should be easy got lad, wouldn't be bothered with wasted spark on a ca, standard set up good enough to 300bhp, just get a set of coil packs for it, what's the car doing breaking down at high loads or not reving past 3-4k
    Aug 2010
    Quote Originally Posted by slithertooth View Post
    Always the way man! Coilpacks cost the guts of 300 euro thats the prob and its a tramper so dont want be spending big bucks on it. She is misfiring and spluttering under full load
    MEATH
    Try and get a loan of a good set before shelling out on a set , odd for the four to give up
    Aug 2010
    Is there a way of telling if they are wrecked or not without replacing them with another pair!
    Junior member speedy200sx's Avatar
    meath
    x2 lad, had problems like that with my ca before, turned out to
    be the gear on the exhaust cam that drives the crank position sensor
    worth checking it
    let us no how ya get on
    MEATH
    Kyle tbh you'd want to get it beside another running ca18 and just swap over a few bit's , they can be a bit annoying while trouble shooting as speedy says the cas can be very temperamental, afm's can also cause similar problems as can break's in the engine loom. injector relay's , ecu's but everything is easy got at and swapped over so don't worry, i'm sure one of the ca heads on here will accomodate you in trying a set of coils first, i'm nearly sure i binned all my ca bit's but i'll check tomorrow ,
