Results 1 to 10 of 18
Thread: Project Stagea
    Default Project Stagea
    Ok so this is a 1996 Spec 1 Nissan Stagea with an RB25det engine commonly found in a nissan skyline.She is auto and is currently 4WD but the plan is to convert it to Manual and RWD.
    Pic's of it when i first piced it up back in Oct 2009
    Ok so when i got it first she was completly standard...Had so many ideas floating around in my head about what to do with it. Gtr Box and leave it 4wd or maybe even just leave it Auto. Spent a bit of time on Skyline owners and on The aussie's skyline owners and seen a few of them had done a conversion with the Rb25 box and got the front diff removed and the sump welded up. DING DING perfect for me Next step was to find somewhere to start tackiling all the work involved so myself and TBK found a shed big enough for both of us to work on our cars.
    Pic's of the Stagea going into her new home for a while:
    Ok so first things first now that its safely tucked away was to start stripping her down as i wanted to get the engine out so i could freshen everything up and get the gammy auto box and torque converter off. I'll let the pictures do the talking.....
    Most parts from the engine have been removed now ie aircon,altinator,starting motor,Rads and so on...only thing ledt is to drop off the bottom wish bones and try and remove the front drive shafts as once these are removed i can get the engine out and the sump off and get it down to Joe in Custom metal works so he can remove the diff and weld her up.
    Next up was to remove the gearbox and half shafts and remove the dreaded torque converter. Big thanks to Tutty as he's the one that got the auto box and front shaft off. only have finished pic's of this so....
    The above pic is of the auto spigot bearing that i somehow have to get out so i can replace with a manual one.
    next step is the interior: Removed the front seats so i could get at the centre console as i've to cut the hole out for the gearstick to come through.
    and also to get in at the pedal hand brake and release cables
    And a pic of where i've to get the master cylinder through to conect up with the clutch pedal.
    I'm in no rush to get this done as i'm enjoying the time i'm spending on it and i want to get it to come out just right. As this car is so rare still over here i can honestly say it will be staying around for quiet some time as there's endless possibilitys and upgrades for it no matter which way it goes.
    The only problem i found on it so far while doing the work is a bit of the plauge under the wing mirrors but it's only the outter skin so it can be cut and welded
    25/Aug/2011 Update
    ok so small update on te work thats been getting done
    First up is that the engine is out and now have an empty bay
    Next up was to remove the Diff and sump so i can cart it off to the fabricaters to ge it modded so she be RWD
    Size comparison between mine and a starlet sump
    And i also aquired these from Carlcf4 which i got stuck into straight away...Cheers bud
    When i collected them.
    Primed up for some paint
    Painted in Ford Velvet Purple.
    Finished Product
    i'll just keep battling away at it and i'll keep updating this tread as i go. :happy)
    All comments and suggestions welcome bt
    Spec list so far:
    Arc airbox exchanged for brand new Apexi Filter
    Japspeed down pipe
    5Zigan decat
    R33 fujibsubu exhaust system that has to be extented to suit the stagea
    Hks adjustable actuator
    Hks EVC3 boost controllor
    Hks Turbo timer
    Hks ssqv version 2
    Tanabe front strut brace
    Will update the speclist when i aquire more goodies
    Limerick
    That is gonna be one cool project....
    di Member srbrian's Avatar
    Kerry
    Thats a cool project, I always loved the Stagea. Are you going to convert to a GTR front?
    Aug 2010
    Sweet project man, best of luck with it
    http://tyresdublin.ie/
    https://www.facebook.com/pages/Tyre-...42971845756587
    Quote Originally Posted by daz1996 View Post
    fair enough and all that but you make it sound like your fuckin james bond risking your life everytime you take a few pics
    i fucking looooove these, great project man ill be keeping an eye on this one best of luck with it
    Jul 2010
    Meath
    Bit different since I last saw it
    cool yoke man, besta luck with it
    di Member ger15's Avatar
    Cool ,will be sweet yoke when your finished it
    Dec 2009
    Sligo
    sweet she'l be sum wagon when shes done dude fair play
