Results 1 to 10 of 20
    Default My skyline won't start help!!!!
    Came home from work and car was fine came back out a hour earlier and it wouldn start? The engine started and was spluttering cut out and now it won't start, also there is no ignition lights? I checked all the fuses and it seems ok and checked and there is power going to the full pump but not sure if it is working but has power? Any help would be great guys
    It's a 97 r33 gtst forgot to say
    Chris Martina
    i call this a dtd post ! check your intercooler piping ,have you juice in it etc etc cant be a mystery !!
    say fuse gone in the fuse box in the engine or dead battry ...........
    no power = no igiontion lights
    say that why it not startn ...........
    is there any lights at all???
    cam angle sensor,
    check the 75amp fuse in the fuse box too (if there is one)
    What's a cam sensor? I tries the batter with a booster pack and that's notthe problem, it's jus the ignition lights all else is working, also my mate jus checked and fuel pump Ian working he thinks? But then why wud ignition lights not work?
    sensor on the front of the timing belt cover, the one in my r32 just gave up out of no where, but saying that i had ignitiion lights
    your fuse lad on in the engine bay think its a 75 amp
    Junior member speedy200sx's Avatar
    meath
    sounds like something simple enough if the car was runnin grand
    before this happened, is there immobiliser, im pressuming it just turning over
    start again with, main fuses inside + under the bonnet
    ignition fuse
    ignition relay
    check for spark
    let us no how ya get on
    Senior Member ste's Avatar
    north dublin
    any alarm or immobiliser
