Page 17 of 37 FirstFirst ... 7151617181927 ... LastLast
Results 161 to 170 of 362
Thread: project sil80
  1. #161
    Senior Member ste's Avatar
    north dublin
    No man be end of june i reckon
  2. #162
    north dublin
    well went to cavan to do few lil bits to it again... the weather didnt wanna play ball today so with the rain was stoppin and starting
    just got this new bigger front mount off lukeworx here its for a s14 and seems to be ok-ish
    had to cut battery tray a good bit
    quite tight on other side too
    i was afraid the vibration or movement may eat into fmic piper so just put some joiners around them to prevent them being damaged..ANY SUGGESTIONS ON BETTER SOLUTION????
    bit bigger than old one
    headlights seem to sit better now too....
    also just lashed in this water temp gauge too nice and cheap
  3. #163
    di Member lsd32's Avatar
    Ste I normally would just get rubber petrol piping and slice it down one side and press it on the the exposed bodywork,if the pipe hits it will only hit rubber
    If you think you can,or you think you can't,your probably right!
    www.ryansautomotive.ie
  4. #164
    north dublin
    ah never thought of that man think i have some of that stuff lying around, thanks man
  5. #165
    Keepin it Chaos
    Carlow
    she's lookin cool now ted... reli coming along.... u heading out for the next mondello day?
    [SIGPIC][/SIGPIC]
  6. #166
    north dublin
    no willy be end of june or so.. collecting cusco camber arms, dw toe arms and dw traction arms on tues then gotta get inner and outter steering arms as mine are worn then down to wez for a suspension setup
  7. #167
    Keepin it Chaos
    Carlow
    be some difference with camber and caster on it........ sounds cool...
    [SIGPIC][/SIGPIC]
  8. #168
    north dublin
    well gettin few more parts bit by lil bit picked these up today....
    was originally only buyin the arms but found out he had the bushed sub frame so was rude to leave it there....
    the dw bushes are brand new, as are the dw traction arms and the dw toe arms,the cusco camber arms are used...
    the sub frame was black when collected it as were the camber arms... so sprayed the camber arms back cusco blue and just used the last of a tin of hammerite i had on the sub frame..
    also just got these 2 lil important bits
    next up is mani gasket and aftermarker track rods and ends
  9. #169
    di Member SRray's Avatar
    Co.Longford
    Coming along now Steven,subframe is a tidy job,heavy feckers to drop down and out on own too!
  10. #170
    Chris Martina
    getn there now boss !
    He came up we chatted for a while nice fella to talk to all the same but he seemed very twitchy and i never trust a twitchy person....!
