SUSPENION AND TRANSMISSION
ALCON(GREDDY)Big brake kit,there 4 pot brake kit(huge pistons),kit comes with calipers,discs,lines ect,,absolutly unreal brake systhem,not like alot of cheap big brake kits ,850.00 euro
os giken triple plate clutch kit for rb engine,clutch is like brand new with 1000 miles on it,was bought brand new,with little or no wear on it,,650 euro,
Os giken twin plate clutch for rb engine,savage clutch,4mm on discs,so no wear on it really
450.00
R33 ohlins suspension,front driver is leaking,the rest are mint,they are harden and soften adjustable,and extremely comfortable on the road,and handle brilliantly
190.00 euro
2way diff,make unsure,locks extremly well,and no play,fully cased,5 bolt skyline output shafts,4.1 cwp(better gearing)
420.00
R33,skyline brakes,front and rear,comes with brake callipers,brake pads, discs, lines ect 200.00
skyline inner strut brace,goes over tunnel and bolts to under seat belts,stiffens the shells unreal,chrome in color
140.00 euro
nismo front strut brace and nismo brake stopper,all in 1
100.00 euro
180sx coilovers,front coilovers are 100 per cent no knocks or leaks and fully adjustable,back left 1 fucked ,
200.00 euro
skyline diff
vlsd, 4,1cwp, full cased incl out put shaft(5 bolt),can be welded if needed
150.00 euro
sr20 drive shafts 6 bolts type,30 euro a shaft or 50 a pair
sr20 std clutch,from nissan in car 8000km,disc and pressure plate
45.00 euro
5 stud conversion available
pm me
ELECTRONICS
nismo clocks for skyline think there either 300km or 320km
120.00
Apexi neo,225
F.a.c.t turbo timer,30
Aftermarket ecu for rb25 series 1,mapped on 550cc injectors and z32,very good ecu,and with good map on it unlike some jap ecu,pm me for more info or questions
150.00
ENGINE AND PERFORMANCE PARTS
1 x rb25 engine,120,000km on it, ,perfect condtion,oil pressure and compression is 100 per cent, is one of the sweetest engines ive seen to date,comes with intake manifold, also uprated turbo. running nice power at 1,3 bar boost
900.00 without turbo or 1000.00 with turbo
rb25 turbo,its off my own r33,on the spec sheet from japan it says uprated turbo,but unsure as i havent checked,its still on the car,and boosting 1.45 bar and no issues and develops big power,,no smoke or play
250.00 euro
r33 blitz nurspec exhaust,has been welded but its sealed
180.00 euro
hks cams for sr20, 264 degree inlet and exhaust
300.00 euro
Greddy Front mount intercooler kit,genuine greddy intercooler kit,pipes come up the same side so no cutting required, direct fit,
280
Apexi induction kit,50
RB20 skyline turbo,std,
no shaft play or smoke,comes with acutator
120.00 euro
RANDOM PARTS
Skyline R33 carbon cooling panel,will fit GTR and GTST afaik
40.00
1x nardi steering wheels, 50.00 euro
also boss kits available if needed,
Greddy lip kit,150
Driftworks 4 point harness,in date,black in color
100.00 euro
COMPLETE R33 FOR BREAKING SO ANY PARTS NEED JUST ASK,MORE TO BE ADDED,,ANY PICS NEED JUST ASK AND WILL TRY GET THEM A,S,A,P
JAMIE
