Originally Posted by
Dunnedriftin
Only need the crank shaft to balance it.
Like no point in surfacing / lightening a flywheel without balancing it because your taken material off it which is putting it out of balance technally! Once is surfaced you then have to balance the crankshaft first, then balance the flywheel & then balance the clutch, its all included in the one price for balancing tho! Im not 100% have to check the price in the morning.
Now we can surface just your flywheel if you want without balancing it, but i recommend doing it right in the first place!
Once you have the above done correctly it will be 100%!
