    Default Tacho Wiring! 'Keyless box found'
    Ok, the craic is....
    Tacho just doesn't work.
    I have a standard J4 ecu.
    I figured the tacho wire in the ecu is a Yellow one with a red stripe.
    This is what I found.
    Then I followed it back to under the dash...
    Coming from the steering column I see the wire. Below this is a random plug/clip (a two bit one) I don't know what the hell goes into it.
    Further down, at the end of this couple of strands of wire I have a box that says 'keyless' on it. I has an aerial, and thats it,. End of the line.
    Only other things I found was a few black wires going to earth around down beside the kicker fuse box, and an earth going up above in behind the clocks.
    Also found A white wire with a red spiral on it, connected to a plug with three bits. Coming off this plugs is an earth.....the white wire isnt going anywhere, it only has one of those plastic connector sleave things......
    Does anyone, anywhere have a clue??~~~~
    Thanks very much,.
    Tom.
    di Member Moose's Avatar
    Mallow
    more than likely a some type of remote start system,
    facebook.com/moosedesign
    If you cant fix it with a cable tie, its broken!!!
