Results 1 to 3 of 3
Thread: rear camber???
    di Member mick-skyline's Avatar
    Default rear camber???
    well i cant find anything really on this so apologies if its been asked before,
    anyway...
    rear camber, i always thought negative camber was what was done (as when cornering hard the negative camber would shift with the weight of the car and in turn have more of the outer wheel in contact with the road), but after looking at a fair few cars after a set up they usually has positive camber on the rear with a little negative on the front...
    can anyone shed some light on why this is done this way??
    Pro Driver
    Ya want about half a degree negative on the rear if your not on all rose jointed arms, with a full solid set up subframe and arms you can run nearly 0 degrees on the rear
    Quote Originally Posted by PeterT View Post
    Incase you havnt noticed, this is driftireland! Not youraveragelookingcountryspeccivic,needsweelsandle sstackyshit.com!*
    Pro Driver
    i think u should always have a small bit off negative camber on the back for cornering. when ur car sqats under power it will ad a bit more camber aswell.
