Results 1 to 8 of 8
    di Member conor's Avatar
    Castlebar co.Mayo
    Default 2jz water pump pulley
    im looking for a 2jz gte water pump pully and the nuts and washers that hold it to the water pump it must be a gte as 2jz ge's are different
    its the four bolt type
    like this one http://www.google.ie/imgres?imgurl=h...1t:429,r:9,s:0
    Nov 2010
    they lokk like the one of the 1jz should be handy enough to find
    Castlebar co.Mayo
    depends jzx90 and jza70's run a bastardised hydrofan system with a one bolt pulley and in not sure about the jzz30 the pumps are different any way only slightly tho so i think i will play it safe and hold out for a 2jz gte pump
    Castlebar co.Mayo
    bump anyone?????
    Pro Driver
    might have one.... ill check tomorrow....
    Castlebar co.Mayo
    Quote Originally Posted by nigey00 View Post
    thanks dude let me no
    Castlebar co.Mayo
    someone must have one surely
    Castlebar co.Mayo
    still stuck for this a jzz30 one MIGHT suit would have to be cheap tho
