So I got the rx7 back together and running tonight so heres what it got and here's the problems;
New front mount, alloy rad, changed spark plugs, oil, filter, new coolant, new power steering fluid, relocation of battery to boot, new piping and few other bits.
When I turn on the lights the engine revs up by about 600 - 800 rpm, opposite to the usual, quite strange
the plug on the ecu for the commander is a bit loose and the wire from the commander going into it doesnt read unless you push it to one side, can this be fixed?
It is now hunting again from 1000 - 1500, been over the car with a toothpick. Thought it was the co2 screw on the throttle body but this doesnt help the problem either (2-3am nearly every night the last week double checking everything and replacing anything that needs it, defo no split pipes or boost leaks)
Need a bit of help here on sorting this out, head is melted
Thanks
