Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    di Member NIALL JZX's Avatar
    tipp
    Quote Originally Posted by Scamper View Post
    Ive a gallon of juice in the shed and a lovely fancy flip up lighter if your interested.
    haha . might ring quinn an insure it fully comp 2moro....
  2. #12
    tipp
    bump , can anyone else shed some light on this ?
  3. #13
    Those toyota keys wear away!
    When hotwiring cable tie the chip end of the key to the barrel and then hotwire!
    Edit-This is from experience in Toyotas,Not stealing cars
  4. #14
    Dublin
    This happened a mate of mine in a corolla . he had to get the barrel rebuilt and a new key done ,but while he was waiting he was using a screwdriver but had to have the key selotaped to the imobiliser for it to read the chip in the key.
  5. #15
    Quote Originally Posted by dbyrneae86 View Post
    this gars bucket of duirt? lol
  6. #16
    Dublin
    Tis haha got stuck up in mc donalds one night took us ages to get it goin
  7. #17
    tipp
    thanks guys was jus at it , have it sorted now nearly..
    when i took the eletric part from the back of the barrel the white casing stayed in it cause there was cable tie on it.. but anyway it came apart an the copper rings fell out. put it back together then , had the key taped to imobiliser , still no go , only earlier i spotted another little copper ring had fell in between the wiring , so split the eletrical part , put all back together an starts no problem with a screwdriver.
    only thing is , is the steering lock comes on wen ya turn the wheel- when no barrel in housing , put ya can flick it back in the housing with a screwdriver.
    my ignition barrel is wanked so wouldn trust puttin that back in to keep the lock off , cause its only a bear turn of the bottom piece that turns it off and on..
    will get new barrel on monday an stick it in and all should be sweet.
    said id throw this up for future refrence in case somebody gets the same problem , may be of some help..
  8. #18
    di Member Scamper's Avatar
    Good stuff lad, your sorted so
  9. #19
    tipp
    yep jus get a new barrel an key an a door lock and it should be grand
