Results 1 to 10 of 12
Thread: blue smoke
    di Member haydn itr's Avatar
    Dec 2010
    Default blue smoke
    iv had a smoke problem for about 3 weeks , just want to confirm if its the turbo theres a bit play in the turbo alright its a heavy blue smoke when engine is on over run ,
    di Member Scamper's Avatar
    Blue smoke means oil problem man, white smoke is water, i know that much, someone with a bit more knowledge will prob tell you exactly wat it is.
    Dec 2010
    i new it was oil alright
    Oct 2009
    Galway
    maybe a valve seal!?
    possiably rings!!
    ye id do a leak down test before changing the turbo, if you cant get a leakdown test done then a compression test might show if there is any blow by but a leak down is the best
    Dec 2010
    any know whats roughly the price of a leak down test?
    di Member andy t's Avatar
    could be da turbo seals... i had that problem before with an s13
    Team Twenty !
    SR20 in the front 2way in the back!
    Flat Out! Eoin R.'s Avatar
    Tipp
    as you said its not blowin blue smoke all the time doh,so id say turbo seals happend to me before aswell...
    Dec 2010
    turbo seals = new turbo ye! ye id say the smoke would be hapnin more than just on overun if it was the seals etc
