Originally Posted by
chrisb
what boost are you running?
non vvt head i take it?
when you up the boost on this type of engine you get blow by, the standard breather system works quite well but is ugly
you need proper crank case ventilation on most engines and the best way of doing this is to apply a vacume to the crank case
the non vvt rocker covers are poorly designed and need modified to do it properly, vvt rockers are much better in design and if chopping the front off one and welding the front of a non vvt one is an option, do that
if not there is a way of modifying your rocker cover to make it preform better along with correctely placed cath tank and piping you will not have any more problems
