Results 1 to 10 of 14
Thread: Psi???
    di Member mick-skyline's Avatar
    Default Psi???
    so went to the garage the other day to check the psi in the tyres as i hadnt done it since the snow and they were all over the place. so i put 30psi into them all,
    but got me thinking, what psi do you lot put in and why??
    i know some over-inflate for breaking traction and some keep them a little low for more grip, but what you you say is the ideal psi on a low profile slightly stretched tyre
    enter derk.....
    i`d go with 32 in front and 35 in the rear on 18`s mick...
    [SIGPIC][/SIGPIC]
    Senior Member tomsheen's Avatar
    Oct 2009
    32 in front on any low profile i have anyways
    65 in the back in my old e30 haha and 45 in the back of my lexus
    65.... must be for a bit of slideing tho tom.... surely was like a top fuel jobbie going down the road..
    [SIGPIC][/SIGPIC]
    Oct 2009
    Quote Originally Posted by larry kehoe View Post
    she was a welded 316 haha it needed all the help it could get
    Gal Dori
    Dungarvan,Co.Waterford
    30 in the front, 60 in the back!
    Jul 2010
    Connaught
    on the road anything from 28-32 allround but on track around 55-60 in the rear tyres, i have a option dvd here going in to all the different tyres and psi they run in d1 i think the lowest was 55psi and the highest 72psi in the rear if i remember correctly
    im guessing it would have a lot got to do with the grip level of the tyres they use as to what psi they would run to try and get a good balance for the driver
    On the track it obviously depends on alot of different factor, wet/dry especially. I used always run 25psi on the front cold, with kumho track Tyres, and anything from 50 to 65 in the back, but those pressure on the back dropped to 30 in the wet. Worked grand for me.
    Dec 2010
    holy shit 65psi !!! i run 30 usually all round
    Apr 2010
    but surely when spinning the wheels up during drifting the psi would increase due to the heat no?? thats mad putting in so much air!heroes haha
    anyone wanna swap s15 helical lsd for 1.5 or 2 way...
