Results 1 to 10 of 250
    di Member thegosson's Avatar
    pressure testing the intercooler
    removed the EGR
    removed the charcoal canister
    tein tie rod and end beside a stock one
    hks down pipe beside the stock pipe
    tomei expreme turbo elbo
    fuel pressure regulator installed
    so i then moved on to making a dash piece to hold all my electrical goodies.
    started with this
    which then turned into
    and then with the gadgets installed it looks like this
    im pretty happy with how it turned out, so much so that i took a video clip of it all beepin and flashing and what not, and as soon as i work out how to post it i will
    see if this works
    YouTube - thegosson 180sx drift dash
    the engine bay before
    and after
    YouTube - thegosson 180sx drift engine bay
    and a few pics while i had her out running in the new diff
    ok so was up at track day performance (tdp.ie) all day today and got my geometery and suspension setup. its set to
    2 1/2 neg camber on front
    1 neg camber on the rear
    slight toe out on both front and rear.
    also got my hks evc plumbed in and set up, and got the power fc installed and mapped. so then it was time to hit the dynapack.
    yellow is before the map and green is after mapping
    oh and this is still with the standard turbo.
    @ the hubs
    @ the fly wheel
    air fuel ratio
    manifold pressure
    Greystones, Wicklow
    Quote Originally Posted by thegosson View Post
    @ the hubs
    Haha that some amount of torque for a standard turbo
    My god shane thats some work you've done, did ya do it all yourself?
    As for the wheels, im using 17x9.5's at the mo and for general road use i found
    235/40/17's good, or mayb 235/45/17 for more comfort or to fill the arches a bit more.
    For drifting mayb a 225/40/17 or 235/40/17, just keep the sidewall low!
    Awsome car, thumbs up to ya, cant wait to see it finished!
