Results 1 to 10 of 250
    di Member thegosson's Avatar
    painted the diff case for shits and giggles!
    then fitted it
    cage fitted
    B&M 40% reduction in stroke fitted
    walbro fuel pump being installed
    d-cat pipe in
    now for the hydraulic hand brake.
    welding the base to a plate for better fit and stronger mounting to the car
    and the whole unit mocked up ready to be installed.
    made up some eye bolt plates to bolt in the harness
    then the seat........:smokin:
    on goes the new bonnet.... carbon fiber:worthy:
    then off with the standard bumpers and wings
    starting to look more aggressive already
    nice.....:smokin:
    and a glimps at whats going in there place
    all original origin areo
    a quick snap of the defi gauges
    takata harness
    rear bumper about to be painted
    ok so now it's time to tuck away the looms.
    the before
    and the after
    and the same on the other side
    50mm spacers to allow for when i put on the 50mm wider rear overfenders.
    marked out the new arch
    then cut:smash:
