Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Quote Originally Posted by yowdy View Post
    ah man u serously have no luck,,sounds to me like the diff isnt sitting rite in the case if you put new bearings on the diff
    aw i no man im pure stressed here.. and can it be fixed andy or is dat another diff fucked??
  2. #12
    Team ManFoot Famous jh's Avatar
    Dungarvan, Co. Waterford
    Sounds to me like the crown wheel end pinion just dont match... You got em both seperate you say? They could have different wear patterns to eachother...something you wont really see by eye like... Thats my pennys worth anyway, seen it happen before...Always best to get them as a pair..
  3. #13
    so basically lads if i took the diff apart will it be broke or can it be put together properly???
    im fuckin stressed out over the ting
  4. #14
    just get a standard welded diff inna a casing if its broke
    shouldnt cost to much
  5. #15
    di Member wayne.c's Avatar
    Quote Originally Posted by davemc-s13 View Post
    u'd have to get it checked out to see does it match up. it could be a wrong match.
  6. #16
    me mate whos fairly handy with cars ( he can make ecu,s) is gonne rebuild it proper
    he said its the backlash so cheers lads for all the help i apricate it
  7. #17
    jus seen dis there lad. some bad luck i swear
  8. #18
    cork
    it aint backlash.
    as said above,crown wheels and pinions are a matched pair.
    you cant just go mix and match em.
