Evening All.
Just having a look around on here. Looks like a very good site.
Below is my Mk1 Ford Capri. It was built first as a vintage car and is slowly moving towards a 'Vintage Drifter'.
Have done a couple of vintage track days and thrown it around in a few corners. Total novice but must learn some where. Hopefully i'll get more track time this year....
Well done with the forum and hopefully i'll see a few of ye at some track days...
Body & Interior
•1973 Mk1 Capri with flared Wheel Arch's from a Mk3 Capri
• Bonnet Vents from a 2007 Ford Transit bulkhead
• Britax Folding Sunroof
• Ford Focus Sunroof Wind Deflector
• 3 Litre "Strengthening" Plates added to the 1600 Shell
• Modified Gear Box Tunnel for MT75 Gearbox
• Re-Sprayed Metallic Aubergine
• 3000 GXL Headlights & Grille
• Re-trimmed Seats from an RS Turbo Escort
• Custom made Roll Cage
• Flocked Dash Board & Door Cards
• Deep Dish 350mm Steering Wheel
Drivetrain
• 2.9 Litre, 24 Valve Cosworth Engine from a 1993 Granada Scorpio.
• EGR Valve, Air Con & Catalytic Converters removed
• JR Performance Cotton Mesh Air Filter
• Lift Pump, Fuel Injection Pump & Swirl Pot
• Sierra DOHC Radiator with Twin Electric Fans
• 2.8 Capri Flywheel & Starter Motor
• Escort Cosworth Clutch
• Custom Stainless Steel Twin Exhaust System
• 2.8 Engine Cross-member from a Mk3 Capri
• Hybrid MT75 Gearbox with a rose jointed Quick Shift
• Modified Drive Shaft from a Ford Sierra & 2.8 Capri
• Atlas Axle with a Limed Slip Differential & 3.77 Ratio
• 15x8 Superlite Wheels with 215/45R15 Tyres
Brakes
• 2.0 Litre Capri Servo from a Mk3 Capri
• "Large Bore" Landrover Defender Master Cylinder
• 300mm Front Brake Discs
• Ford Focus RS Front Brembo Brake Calipers
• 253mm Rear Discs from a Ford Mondeo V6
• Sierra 4x4 Rear Brake Calipers
• Hydraulic Handbrake
• Brake Bias Valve
• Braided Brake Hoses
Suspension & Steering
• Modified Granada Cosworth Steering Rack (2.6 Steering Ratio)
• Complete Polybush Kit
• Coilovers from" Converted" Capri Front Legs from a 1600 Mk1 Capri
• 300Llbs Pound Springs
• Adjustable Suspension Inserts
• Roller Bearing Suspension Top Mounts
• Rose Jointed Adjustable Track Control Arms
• Modified Front Anti Roll Bar from a 2.8 Capri
• Single Leaf Rear Springs from a 2.8 Capri
• 1" Lowering blocks
• Adjustable Rear Shock Absorbers
• Rear Anti Roll Bar from a 2.8 Capri
• Rear Axle Location Kit
• Wheel Studs from a 2007 Ford Mondeo
