Results 1 to 6 of 6
    Default Updated fuel pump
    Say I buy a warlbro. Do I need a Fuel Pressure Regulator? Was a bit shocked when I seen the FPR was 100 odd pound. Can some one explain?
    Thanks,
    Thomas.
    Jul 2010
    cork/limerick
    as far as i know you dont but i could be 100% wrong
    Dec 2009
    You wont need a FPR
    Sig removed - See rules
    as above no u wont
    Can someone go through the theory? Why, why not, etc? Cause if I want this SR to move anywhere In a slightly brisk manner, I may start sorting her out, fuel pump first, then go from there.
    Nov 2010
    Dublin
    Quote Originally Posted by serious tom View Post
    This is nothing that the google fella can't answer..
    The amount of fuel supplied to the engine is determined by the amount of time the fuel injector stays open. This is called the pulse width, and it is controlled by the ECU." - How does it calculate pulse width?? It monitors all the sensors in the car such as MAF, throttle position sensor, coolant temp sensor, voltage sensor, manifold absolute pressure sensor.. engine speed sensor and the ecu runs its calculations on all these sensor readings keeping a map for lookup to keep track of whats going on.
    A regulator keeps a certain amount of fuel pressure in the rail and then sends the rest back to the tank.
    Your car as well as most fuel injected cars have a one to one fuel regulator. It varies the fuel pressure by 'watching' manifold pressure. It uses a diaphragm to control pressure. Most Nissans at idle (vacuum) fuel pressure is 34psi and at full throttle (No vacuum in theory) 43psi. If you further put pressure (turbo or super charger) to the manifold, it further increased fuel pressure. In factory regulators, for every pound of boost, it adds a pound of fuel psi. Hence 1 to 1.
    Most adjustable regulators are still one to one or close to that, however you can adjust the pressure at idle or full throttle for fine tuning.
