Results 1 to 10 of 10
    Nov 2010
    Dublin
    Default URGENT:: defi gauge cabling??
    I know this is a bit of a long shot!! Poxy oil and water sender cables that connect to the controller are wanked!!
    Has anyone got these cables??? If not, anyone know how much they are from Defi..
    Cheers
    i seen them on ebay the other day for about £45+ each.. not cheap!
    http://cgi.ebay.co.uk/NEW-Defi-Oil-W...ht_3064wt_1139
    http://cgi.ebay.co.uk/Defi-Oil-Water...ht_3026wt_1139
    Nov 2010
    Dublin
    Post
    Cheers Conor, ye I spotted them alright. Ridiculous price for a bit of cable! My uncle knows someone who's works in an electronics place, get him to have a look at, hopefully the connectors are standard.
    No gauges for mondello next sunday so!
    di Member NIALL JZX's Avatar
    tipp
    send me a pic of the connectors on both ends , and the wire colours also , think i may have some spares there , will check when u send pics
    di Member dave_sr20's Avatar
    Dec 2009
    Kildare
    whats the problem with the wiring is it the connector blocks or the wiring itself
    Nov 2010
    Dublin
    Quote Originally Posted by dave_sr20 View Post
    Its the actual connectors.. the wires just fell out of them!
    Dec 2009
    Kildare
    from the look of the first pic someone handy with a soldering iron should be able to sort it out for you
    Nov 2010
    Dublin
    Yeh just tried it there with an iron.. fucked it up. Now I defo need new out meter connector. BALLS!!!
    Nov 2010
    Dublin
    I Need 4 cables:
    1. A piggy back cable which goes between gauges
    2. The output Meter Cable which connects the controller to the piggy backed gauges.
    3. Oil and Water temp harness which connects the sensors to the controller
    Sure gis a ring, 0863976383.. or ring me and i'll ring ya back
    Nov 2010
    Dublin
    Pic of piggy back cable connector & oil/ water temp connector
