Results 1 to 5 of 5
    di Member Scamper's Avatar
    Default Question about fitting spacers??
    Hi all
    Ill try keep this as simple as i can
    Basically im fitting 20mm spacers to my car so that my wheels sit right.
    When i fit the spacers and bolt them on, the original studs from the hub stick out through the spacer, which means when the wheel is put on the spacer studs it cant go flat with the spacer as the hub studs are sticking through preventing it from doing so.
    Now the works wheels have 3 holes where it meets the spacer, for the hub studs to go into, but 2 of them dont, so do i just cut these two hub studs so that all will line up, or get smaller hubstuds of nissan or what??
    Hope i explaned that right??
    Cheers
    Scamper
    cut em is prob easier.... jus stick a wheel nut on first so ya can restore th threads wen ye cut them
    Quote Originally Posted by twailbait View Post
    Im happy as long as every one acknowledges that you have a large quantity of retardation in you.
    di Member twailbait's Avatar
    Yeah just chop them a wee bit. And as mick said put on the wheel nuts first, so after there chopped just unscrew the wheel nuts and they'll fix up the threads.
    Cheers lads, thanks!
    Sorted this today thanks for the info again lads
