Results 1 to 10 of 20
Thread: Idling problem
    my car had exacly the same symptoms,turned out my ecu was sending funny signals to my fuel pump,cutting it off for a second and not signaling it properly so the car would rev smooth,i had this problem for a while,wired the fuel pump direct and its be fine ever since...i dunno is your pump wired direct or what...
    yup the pump is wired direct to the battery via switch.
    Danmoorhead reckons i could have a vaccum pipe disconnected.
    Another thing is that the car hasnt ran in a while, would that contribute to it??
    No haveing it sat for a while shouldnt cause that,was it running fine the last time you started it?what work have you done to it since...it does sound like a vacum pipe,air in the system or maybe a airflow meter issue....?if it was running fine before and you havent been working on it,then obviosuly there cant be vacum pipe disconnected,could be a split pipe,is the cooling system bleed?
    Aug 2010
    Have you checked the idle control valve? I had the exact same problem on my rx idling between 1k AND 1.5k so i brought into eddie doyle and he told me to adjust the idle control valve, located on the throttle body elbow on my rx7. twist the screw in all the way and then screw out 1 & 1/2 turns and then check, if problem persists, screw out another 1/4 to a 1/2 turn....
    This worked for me!!!!
    http://tyresdublin.ie/
    Quote Originally Posted by skinnynphats200 View Post
    From what i can hear,the car seems lumpy through the rev's...the idles control valve will only effect ideal and shouldnt affect performance through the rev range!
    Aug 2010
    Is the car not idling on its own with no throttle at all from 1.5K to 2K and back to 1.5K etc, etc...Thats what it sounds like anyway! Adjusting this idle control valve will set the idle back steady and it will stop hunting on its own, well should do anyway, correct me if im wrong but this was my experience and it worked for me. That was 2 days ago and it hasnt happened since....maybe i got lucky
    yes your right,i watch it again,the first time i taught there was some reving,but there isnt my mistake....
    Aug 2010
    Yeah its a bit blurry, Ya have to concentrate to hear it right
