Results 1 to 5 of 5
    Default blitz DSBC... Help setting up
    anybody usin this boost controller? What settings are ye usin and what bar are ye boosting? I just want to get the r32 boostin strong to .65 or .7bar. Any suggestions on settings? Save me wasting an hour of my life stoppin and adjustin settings
    Old type or new type with big display screen...
    if its old type......
    Knob on left toggles through your channels...1 to 4...Easiest thing is try the car in each channel...Chances are the previous owner has set a few boost levels already..
    If not set it to channel 1...Press it I think twice till it says set and a number ie: (30)...use the right nob to turn it up or down depending then press right nob then left one till it stops flashing...
    If your getting massive boost spikes...select channel 1...press and hold left button for 3 secs till the gain number shows...Turn it down with right knob...Or if boost is very slow to rise turn it up...press right button again then...
    Rough idea of how they work...If its late type on its different...Go to menu...set to manual...Turn gain to roughly 30...then adjust your set up or down...
    Also set warnings...similar method...
    Dec 2010
    if u google it dare is some very handy manuals come up.. very easy follow..
    Did you sort the misfire?what was the problem in the end?
    yeah t.j miss fire is gone. Regapped the plugs and checked the springs inside the coilpacks.... Running lik a clock now just hav to get the boost sorted... Cheers for al the info guys. There is no preset boost settings on it.
    I had the manual at home how to adjust the settings just thoughj id b lazy and see did anybody already have settings..
