Results 1 to 3 of 3
    Default S15 Gearbox issue
    a buddy of mine who'd be a very competant mechanic got a S15 in for a clutch,replaced the clutch and with the box back up it'l take 1st 2nd and 3rd okay,wont select 4th,will select 5th 6th and reverse but will grand and will not drive....he didnt drop the box,put in an exedy clutch,used the old release bearing...had the shifter covered while the box was out...any ideas,i presume the box will have to be split...?
    i take it he had all the gears b4 hand ya? would that be the reason y the customer wanted a clutch fitted
    Sounds like he might of filled the gear oil in the wrong hole
