Results 1 to 10 of 10
Thread: m3 engine / box
    Default m3 engine / box
    Right lads have a couple quid together and not too sure how to use it.
    Have a lovely 318is coupe at home standing me nothing being wasted away parked up.
    how much to buy an engine / gearbox / diff and loom(is it needed) from an e36 evo.
    Aug 2010
    Newbridge
    I have gearbox,propshaft,diff from e36 evo-400,80,300e if you want it?
    drop benbimmer on here a pm,
    he'll prob be the best to sort you out lad.
    sound lad to deal with too.
    Dec 2010
    I've gearbox, propshaft, diff, subframe from an evo,
    350, 50, 300, 100 or 700 for the lot?
    Quote Originally Posted by reckless View Post
    nice first post!!
    m3 evo gearbox's rear subframes and diffs are shite!! if you are putting in m3 stuff for a track or drift car only use 3.0ltr stuff as they are far easyer to get diffrand ratios of diffs!
    Dec 2010
    I know that for track use the 3.0 bits are stronger alright, building an m3 based race car myself. I got the impression this was for a road car - and they seem to be asking for the evo box and diff.
    Dec 2010
    Just to add, I do have a 3.0 diff for sale as well, mint condition, 350.
    Letterkenny , Co. Donegal
    Put up an intro now and project thread
    Cork
    For an M3 engine, gearbox & propshaft, loom, ECU&EWS and maybe a rad you would be spending around 1000-1500.
    To do it properly...
    You'll need the front suspension and brakes, rear axle, diff and rear brakes too.
    To be honest, considering the costs to get all the bits and fit them... I'd nearly just sell the 318iS and buy a good M3 Evo unless the iS is abit special to you or something.
    Quote Originally Posted by gem-s13 View Post
    nice first post!!
    Nothing wrong with them as you can use a 3.91 cwp and you'll have the 210 casing diff then to make a sweet LSD that'll take far more abuse than a 3L one. You can get 3.46, 3.63 and 3.73 ratios for them too.
    188 casing diffs are only an advantage if you want to use a ratio higher than 3.91
    3L bits aren't stronger!
    Dec 2010
    So, the 3L box is no stronger than the 3.2? I have heard of 3.2 boxes breaking all over the place. Fair enough on the diff.
