right lads i will be getting over fehders onto my 180sx i want 2 know who be the best lad 2 do the job dnr want no butcher with a grinder just 2 chop and rivet want it done properly would also like 2 see the persons work if any 1 can reckamend them
check out jays 180 build thread!
see this now, did he put anything then between standars arch and wide arch like expanding foam etc?
nope! no need sure, cut up the standard arches, seal them up so dont rust, and off ya go, rivet away!
ya use some expandin foam in behind the fiberglass i done it on mine an ya can lean your full weight on them not a bother
My S14 Rollin shell For sale
http://www.driftireland.com/forum/sh...ad.php?t=31509
You can do it by cutting the outer arch and then slicing the innner arch and bending it out, or you can just cut out the arch, weld on a flat sheet bent in the shape of the arch which will come out to the overfender. Once the over fender is on expanding foam is the job! Just make sure you seal up the arches under neath first![]()
no need for any cutting.!
give dan moorehead a buzz. highly recommend!
Team WKD
