Results 1 to 10 of 20
    Sep 2010
    kerry
    Default 2way diff ratios?
    well lads, anyone tell me what the ratio's on two ways stand for i.e 4:1???
    i want a 2way but dont understand the ratios
    cheers lads
    1 turn of the prop= 4 turns of the wheels.. is an example of a 4:1
    3.9 real long gearing slower accelerating
    4.1 gearing a bit shorter slightly quicker accelerating
    4.3 shorter gearing quicker accelerating
    4.3 you would be pulling 3rd gear around most pd street tracks (near standard power)where a 3.9 would'nt have the legs for 3rd unless you were flat out on long track like mondello carrying plenty of speed..
    Higher up you get to a ie 4.9 you get the quicker acceleration and higher gear you can pull
    Dunno if that make sense to ya ha
    MEATH
    you get the final drive ratio from your crown wheel= 4 and pinion =1 as jonny said , but if your buying a new 2way to fit your car ratio will be whatever's in your car, it's only if your buying a cased diff that you'll be told the ratio! if that's any help
    Sep 2010
    kerry
    sooooooooooo 4:3 would be prob the best diff as i dont want it for any fast stuff,2nd mostly like?
    thanks stevo
    Quote Originally Posted by dermot-r32 View Post
    thanks stevo
    4.1 would be a good second gear diff
    4.3 would be better geared for pulling third (easier to pull 3rd than a 4.1 with standardish power)
    What bhp have you got?
    Sep 2010
    kerry
    standard rb20,only exhaust,
    4.1 for second gear drifting with your power (you'll pull 3rd through the s's in mondello)
    4.3 would make life easier for pulling 3rd everywhere else
    Sep 2010
    kerry
    cool.ill look out for a 4:3 one so id say,
    thanks lad.helped alot,
    MEATH
    what's the final drive in a 32,?
