well lads, anyone tell me what the ratio's on two ways stand for i.e 4:1???
i want a 2way but dont understand the ratios
cheers lads
cheers lads
1 turn of the prop= 4 turns of the wheels.. is an example of a 4:1
3.9 real long gearing slower accelerating
4.1 gearing a bit shorter slightly quicker accelerating
4.3 shorter gearing quicker accelerating
4.3 you would be pulling 3rd gear around most pd street tracks (near standard power)where a 3.9 would'nt have the legs for 3rd unless you were flat out on long track like mondello carrying plenty of speed..
Higher up you get to a ie 4.9 you get the quicker acceleration and higher gear you can pull
Dunno if that make sense to ya ha![]()
you get the final drive ratio from your crown wheel= 4 and pinion =1 as jonny said , but if your buying a new 2way to fit your car ratio will be whatever's in your car, it's only if your buying a cased diff that you'll be told the ratio! if that's any help
