new plugs and coilpacks and fuel filter done recently too
You check the air flow metre???
did u try read the fault codes see if its flagged some thing?
I think you car is trying to tell you stop fucking "diffin" me
and DRIFT me.
on a serious note sounds like fueling problem just make sure the sock on the fuel pump isn't blocked
The sock on the fuel pump is clean
petrol tank is clean
new fuel pump that we know is working from another car (hard wired)
new plugs, properly gapped
new coilpacks (know are working)
new fuel filter
he put in an adj fuel pressure regulator and propery set up.
the fuelling is spot on up to and coming out of the fuel regulator. he put extra earths onto the injector side of things.
hes getting a loan of an ecu for me and well check the air flow meter aswell
but if anyone has any ideas or experiences that they fixed let me know please, thanks
Did the pump run out of fuel or go very low at all for some time? As the pumps dont like that at all and they to burn out and yours could be dammaged...
check the plug on afm
As said we tried another pump that was working perfect out of a car so its not the pump i don't think.
Cheers will try that Jamie
check ecu earths, came across a ps before cutting out mid slide was ecu earthing incorrectly when momentum caused stuff to move around..
:edit: sorry this is will_c on trixtas profile!
had the same problem it turned out to be an earth .
