Results 1 to 10 of 18
Thread: whining noise
    Default whining noise
    right, need a bit of advice, replaced the gearbox and clutch in the s14a a while back and got around to starting it up again the other weekend.
    when i started it there was a whining noise comming from the car. i shut i off, and tried again and the noise was gone.
    then, few days later i start the car up again and the noise is back.
    i know its comming from the bell housing as its directly affected by dipping the clutch pedal,
    doesnt start and stop as such, just the noise changes.
    its not the gear set itself as theres no grinding and the car does drive forward and reverse okay.
    the best way i can describe the noise is like the noise a supercharger makes.
    i really dont want to pull the box again with no ideas and have the car sitting up another 6 months so can anyone recomend what it could be?
    could it be the release bearing?
    i did replace it when i did the clutch but if it got dirt in it or wasnt fitted right could that be it?
    Oh, and it's an rb25 conversion too.
    anyone wanna pull the box and sort it for me????
    FML
    Four doors 4 more whores
    Dublin
    You sure it's not the MRS??
    Quote Originally Posted by Alan B. View Post
    FML
    If she's dacent i'll have a look
    Sorry! Give Yowdy or Bart @ Just Jap a shout they should be fit to sort you out with that
    "its cool i guess, but where are the other 2 doors?"
    Sedan Life since 2009
    FrSedan.com
    Galway
    ya didnt put in an orc clutch by any chance??wen you press the clutch in wit them they make a dingle dingle kinda of a sound??its normal if ya have an orc clutch
    Meath
    My Cusco clutch makes a similar noise and I'm led to believe it's normal? Although I wouldn't exactly call it loud, it isn't really that noticable
    Dublin
    Actually our Silvia does something a bit similar but it's not very loud. More like when you know it's there you notice it but otherwise you probably wouldn't. I'm told the clutch in it is an ORC Super Single..
    FrSedan.com
    Galway
    Quote Originally Posted by Fredericks Balls View Post
    all orc's make that noise its normal some are bit louder than others tho...you'd notice mine if ya were in the car or standin next too it but ya get used to them
    I Rustle Jimmies twin-cam85's Avatar
    Cork
    yep mine is the same but as said above not really loud
    If It Aint Rubin, It Aint Low Enough
    Dublin
    I haven't driven it in nearly two months I can hardly remember lol. I'll take it out for a spin tonight and see how loud!
    FrSedan.com
    The clutch kit I used was a blueprint kit.
    And it far louder then what you lot seem to have.
    There's no way you wouldn't hear this noise. And that's over he sound of the rb Erving with the screamer pipe.
    Jul 2010
    Meath
    Lots of people on DW are comin back sayin it's prob the bearing
