just wondering will 18x9.5 et30 go on the front without any adjustment or spacer or anything, the car has standard suspension too if thats any help, cheers lads
my 18x9.5 +10 meisters stuck outside the wings a good bit, but the et30 would be 20mm further to the hub so you might get away if you fit a 215 tyre and dial in sum camber.
google is your friend,
I have 18x9 et30 work meisters with 20mm spacers on 30mm overfenders and it sits flush..soooo if ya can make any use of that lol
google.com.......................
here you go...... wheel spec the same on a 15.
http://www.google.com/imgres?imgurl=...26tbs%3Disch:1
fitted the wheels today but there just getting caught on the shock on one side in the front, 5mm spacer should sort it out
