Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
    Default GT2860r now fitted, but wont run properly!!
    Fitted new above turbo 2day with standard s15 actuator..
    Run's perfectly, but when left to tick over car WILL NOT rev..
    You put your foot down and it the engine revs to 2000rpm then bac down to tick over, 2000rpm then bac down again etc etc..
    But as soon as you cut the power, turn car off and start ignition again, it run's perfectly for maybe 10 15 min's then when left to tick over, Happens again...
    It is very hard to explain but i hope somebody knows what it is..!!
    Specs are
    -Standard black top SR
    -Induction
    -Front mount
    -De-Cat Back exhaust
    Any info would be highly appreciated..
    Thanks Conor..
    di Member 1jsoarer's Avatar
    it's prob your air flow meter! Get a z32
    Signature removed
    is it maped to the turbo
    Chris Martina
    jaysus man you got al your lines plumbed back ok ??
    Does it hunt at all?
    why are you reving the car / boosting if its not mapped for that turbo?
    Well im guessing its not mapped for that turbo... Check all your vacume lines!
    Do you want sauce on your kebab?
    Chris Martina
    hahahah.........
    He can boost a bar with a standard map on that turbo, reving it to 2k wont even bring in the boost.
    Quote Originally Posted by slammedmind View Post
    Yeah thats what its doing..
