Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: Power? Boost?
  1. #21
    fit a manual boost controllet or a bleed valve, never mind what u hear they work fine, ive one on my drag car an it sits at 1.2 bar never spikes. u shud really get a downpipe decat, fuel pump, beeld valve and run .8 bar, standard sr's are slow like!:p
    They actually are... My friend didnt want to say it, but his 320 feels far quicker, i had to say it for him
  2. #22
    Sr, Lad!
    sounds like your car is running shite man!!!
    dont worry about decats manis etc till you get it running right to start with (no point)
    as wolftown said check fuel pump (you'll here it prime but pressure may still be shite)
    Afm boost leak etc...
    try borrow an afm and pump...
    hope that helps
  3. #23
    its not low enough!
    is it running good, just slow? like its not spluttering or anything?
  4. #24
    How shall i go about checking for boost leaks?
    It has thee worst FMIC ive ever seen on it, so i dont even know how to go about checking it
    Yea. Im on a budget so I dont know what to buy. I need a rool cage too.. Which doesnt help. Driving test tomoro, so I can finally go around getting bits and pieces from the auto factors and what not, instead of waiting for three weeks for a bolt!
  5. #25
    No just feels like ages when its in high revs. Drove normal (whats normal.. I havent even got a road car..) No its seems ok, nothing out of the ordinary, I just feel like I want to drive it on the road for a bit so as I can get the best out of the car, i.e. learn how it drives best on revs etc. flat shifting and what not
  6. #26
    Sr, Lad!
    get a can of carb spray and spray all the piping joints etc at idle,
    if the idle drops you've found a leak
    i'd say thats least likely though, if its not spluttering etc.. i reckon wolftowns probably on the money,
    I've a spare working standard pump you can have if you get to dub...
  7. #27
    prob jus feel slow cos its only boostin at .4...it should be boostin atleast .6....i reckon the turbo's jus runnin out boost too quick an it jus levels off at .4 an feels slow then cos its still not climbin the boost range any higher...get an upgraded pump an knock it up to .9 bar it'll def make alot difference
  8. #28
    Quote Originally Posted by 2tonne View Post
    Might bring you up on that. Im from Newry. Ill have to see if there is anyone about here with one. But I like hittin Dublin on the bus. some job
  9. #29
    Yea actually that sounds sorta right. Power for drifting, feathering and clutch kicking, but in a straight line, its like there is no boost at the top of the Rev range....
    So fuel pumps anyone?...
  10. #30
    Sr, Lad!
    Quote Originally Posted by serious tom View Post
    No bother,
    if it is really is slower than a 320 then its defo not right.
    p.s. low fuel presssure on boost will also lower boost pressure somewhat
