Quote Originally Posted by Quealy View Post
Just an small update here, myself and marty went dicking around with racks this evening in the missile 32, that solenoid valve that gem was talking about was the problem like he said it would be. Running power direct to the solenoid works, but what we did was remove the solenoid from the valve and jammed an m6 nut between it and the plunger in the valve. Effectively holding the valve shut. Job done. Nice light steering again. Had the car up to 100mph on bumpy enough roads and it was grand, no stability issues!
Changing the rack is prob the best fix in the long run, but this is a handy quick fix if anyone gets stuck with it again
Yaaaaaaay
I dont see any number 11's around, or am i blind?
