Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
  1. #31
    Before i explode! Gem this is for you but if somebody has a 110% answer thats good enough!
    iv got a 180sx Steering Rack, pump & rods & ends..
    Will that all bolt up to my R32 and get rid of all the shite problems iv got?
    Also will i need the 180sx / sr20 pump brackets / fan belt ?
    anything else i need or will it all just bolt together like abc!?
  2. #32
    Quote Originally Posted by Dunnedriftin View Post
    Bump anybody? kinda need to know...
  3. #33
    as i said you will only need the back half off the sr20 pump and mate it to the rb pump with the veins removed this will remove the 2nd pressure line off the pump, the sr 20 pump will not bolt on to the rb engine, i have a pump here done if you want ill swap you for your pumps and it will be just bolt on
    as for the rack yes strait bolt in replacement, you may have to bend the 2 metal pipe a small bit to get them to bolt up but that is it!
  4. #34
    Quote Originally Posted by gem-s13 View Post
    I tired pm'ing you but you got no space!
    Thanks for the reply, much appricated! Il let you know asap if i need your pump etc...
  5. #35
    ye no bother lad, iv been meaning to empty that inbox! give me a ring if you need any more info 0863988285
  6. #36
    Right well i got a 180sx rack & pump.. Fitted the rack tonight and got a supprise to the lock i had also rubbing the chassi leg but thats because the tracking is way out
    Gotta Sort the pump in the morning & then tomorrow evening il go at running/bending the lines from the rack to the pump, really dont want to go at it as im afraid il snap them known my luck and then il be rightly fucked!
