Is the 180 jobbie a direct fit gem? Its a much better way of doing it to be fair!
"...OUR SMOKE WILL BLOCK OUT THE Sun..."
if i have a rack out lad be 60 i deffo have one in a car but be 70 if iv to take it out ill have a root around moro, also you can bolt on the rear section of a sr20 pump to the main body of the rb20 pupm that just saves having to block the second outlet for the rear hicas
So quick fix, change the rack & then i have proper power steering back?
oh a fuk around with the back of the pump but i think somebody has already done that...![]()
Just an small update here, myself and marty went dicking around with racks this evening in the missile 32, that solenoid valve that gem was talking about was the problem like he said it would be. Running power direct to the solenoid works, but what we did was remove the solenoid from the valve and jammed an m6 nut between it and the plunger in the valve. Effectively holding the valve shut. Job done. Nice light steering again. Had the car up to 100mph on bumpy enough roads and it was grand, no stability issues!
Changing the rack is prob the best fix in the long run, but this is a handy quick fix if anyone gets stuck with it again![]()
Soon there will be no stone unturned ha![]()
