Hi guys i had some overheating problems on the rb20det after some investigation i found the standard rad was choking. So i replaced it with a gtr aluminum rad. Im still using the standard fan but i want to run another fan in front of the rad to keep everything cool. I've looked at fans on ebay but ive bein told to use honda civic air con rads as a cheap option. These are a twin fan setup and are meant to push air through the rad. I am goin to hook up the fans using a rad stat and a relay. Has anyone ever done this and which fan did you use and which rad stat did you use to make the fans come on and off at the correct temp. All input
