Hi,
I'm gonna have to use my s14 as a daily now so I won't be putting the cage in it in any forseeable future.
Cage was built by/for APEX Performance UK, to Blue Book specs and comply with ALL current regulations
It's a cage for s14/s14a, SIX POINT THROUGH DASH, double side bars, rear horizontal and diagonal bar etc. All bars are fitted using double bolts (as per regulations) - with 90 degree offsets.
That's what APEX says about them:
Theyre the latest and greatest Apex V2 series. These are hugely specced and easily surpass the MSA cage requirements. Theyre 2010 EDC and BDC complient. JDM All Stars in theory want the door bars welded together and the sandwich plates welding to the car floor.
The cages are designed to run with the full standard interior. Youll just lose the sun visors. If you run both door bars on the S14 then make sure the bolt heads are outward facing (rather than the bolt thread) as the bars and bolts will foul on the door card slightly.
Specifications:
Theyre true bolt in cages so no welding of support brackets, just drill and bolt, job done.
S14 is through dash, S13 is miss dash. S13 has plenty of room for entry exit with the legs missing dash wheras the S14 need to run through dash due to design of the door cards.
Basic cage specifications
Finished in black
45 diameter 2.5mm wall thickness cold drawn steel
Twin bolt fixings at 90 degree for all tube mounting points
All the bolts are 8.8 tensile strength
Sandwich plates to mount under the floor and bolt to the cage feet
Full cages:
6 point fixing
Main hoop
Rear stays
Rear diaganol
Rear horizontal
Removable twin door bars
Removable rear horizontal
Removable rear diaganol
Front legs
Front upper screen bar
Fitting kit with all nuts, bolts, washers and sandwich plates
These cages retail at 499 pounds which is roughly 570 euro plus shipping on top of that.
I'm looking for 470 euro cash.
Please be aware that two rear bars need to be slightly redrilled to fit properly. I found that when I test fitted it.
I'll put pics tomorrow.
My phone 0857111638, located in Cashel co. Tipperary.
Cheers
