well finished off masking it up on friday morning there
first layed down 4 coats of white, think its on its 2nd coat in this picture
then i started spraying the red put down 8-9 coats of red
1st or 2nd coat on in this picture
then put down 5 coats of laquer
came in then on saterday mornin and started wet sanding the car with 1200 wet and 3 hours later and my arm about to fall off it looked like this
then put down some fresh masking just incase of any dust stuck in the old stuff, im only re laquering the outside no point doing in the door jams i blended it out at the bottom of the quarter panel to
well another 5-6 coats of laquer and it looked like this ,its only on its 4th coat in the first picture there
going over now to wet sand it againand buff it up
also started on my wheels going to polish up the face of them
heres one of the centre caps i done you can see the difference here beside one thats not polished. had to start off sanding it with 180 grit to remove the laquer then went through the grade 320,600,800,1200,1500,2000 and the machine polished it.
and buff it up
